ma.jomaa Posted October 20, 2017 Share Posted October 20, 2017 Price: $18950 Location: Granada Hills, CA Description: Up for sale is my 1987 e28 with an LS1 swap with working AC and heat. All work was done at JMP AutoWerkz in Reseda. The list of work done/parts involved is not all inclusive as I will not remember every nut and bolt used to complete the build. Used Parts: -LS1 with around 80K miles. Engine was resealed and a new water pump was installed -Rebuilt T56 Transmission -LS6 intake manifold -Resealed 3.73 Small Case LSD -Euro Bumpers -Euro Headlights -Euro Turn Signals New Parts: -GTO Oil Pan -Pro 5.0 Short Shifter -Aeromotive Adjustable Fuel pressure regulator -New high pressure fuel pump -Chromoly pushrods -CSF Radiator -16'' Spal fan -Water Pump -AC Compressor -AC Lines, AC Condenser and Drier -Heater Blower Motor -Condenser Fan -Diamond Stage II Clutch -Spark Plugs and Wires -Porsche 944 Brake Booster -e32 brake Master Cylinder -e34 M5 Brakes all around: New calipers, Rotors and Pads -Custom one piece driveshaft -Federal RSRR tires in 235/45/17 (Less than 500 miles on them) -New euro bumpers rubber trim. -VDO Oil Pressure gauge -VDO Temperature gauge -Innovate Motorsport Wideband AFR gauge -Custom headers to clear steering box -Engine and transmission mounts -Tie Rods -Upper and lower control arms -Idler arm -Steering Center link -Sway bar links Front and Rear -Rear Pitman Arms -MAP Sensor -IAT Sensor -AC and Drive Belts -Expansion Tank -QTP electric Exhaust Cut out -Custom 3'' exhaust,with mid section muffler, high flow cat, and rear magnaflow muffler. -Euro Bumper brackets Dyno tuned at New Era Performance LLC in Agoura hills, it made 303hp and 330ft/lb TQ at the wheels. Asking price is $18,950 Please don't waste my time or yours with low ball offers. This is a for sale post, and not a survey of whether you agree with what I did to the car or not, lets keep negative comments off the post please. I can be reached at 818-703-2097 Call or text Below is a link to google album of the car. https://photos.app.goo.gl/nCsfu04BUlY0nzy33 Quote Link to comment Share on other sites More sharing options...
CoastalCrush Posted October 22, 2017 Share Posted October 22, 2017 Is the car B.A.R certified? Quote Link to comment Share on other sites More sharing options...
ma.jomaa Posted October 22, 2017 Author Share Posted October 22, 2017 4 minutes ago, Coastalcrush408 said: Is the car B.A.R certified? It is not. Quote Link to comment Share on other sites More sharing options...
KenH Posted October 26, 2017 Share Posted October 26, 2017 Dang you selling this one already ?? Quote Link to comment Share on other sites More sharing options...
