$800 of Brand NEW suspension parts for $380
diathermic
Price: $380
Description:
(lowered price!)
These are parts I bought extra from my '72 Tii suspension rebuild.
As you can see in the picture they are all NEW unused parts.  To make my life simple, I would like to sell this all as a LOT at 40% off.  So if you are rebuilding your suspension and planning on doin' it right, this will save you well over $400.
The exact items are listed below.  Total paid was $812.40  You can have it all for $380 (+$30 shipping if you can't pick up in SF Bay area)
You may think buying all of these bolts was silly, but I was sure happy I replaced all of my critical bolts with news ones when I did my rebuild.
Details:
Company Part No. Description Qty.  Cost Ea  Total
Massive Massive Massive Roll Center Spacers, 25mm thick, Straight 1 set  $  100.00  $  100.00
Ireland Eng [adjtoekit-lock] Adjustable RearTOE Kit - Posi-lock style 1 set  $    95.00  $    95.00
Ireland Eng [adjcmbkit-lock] Adjustable Rear CAMBER Kit - Posi-lock style 1 set  $    95.00  $    95.00
Ireland Eng [02pd3dot] Rear 3-DOT (37mm) Upper Spring Pads - 2002 1 set  $    60.00  $    60.00
Ireland Eng [02rsbushi] Rear Subframe Mount Inserts / Bushing Stiffeners 1 set  $    29.00  $    29.00
BMW OEM 33323628167 Bushing Pin - Priced Each (see Rear Axle Carrier Drawing 33/27) 2  $       9.42  $    18.84
BMW OEM 31111136250 M10x70 Bolt 10.9 for Rubber Mountin on Rear Axle Carrier 4  $       9.48  $    37.92
BMW OEM 26111205004 Square Screw for Drive Shaft Center Bearing Mount 2  $       8.00  $    16.00
BMW OEM 33413404109 Rear Axle Spacer Tube 2  $    40.84  $    81.68
BMW OEM 7119914667 M12X1.5X90 for mounting rear Diff 4  $       4.45  $    17.80
BMW OEM 7119905162 Hex Bolt 2  $       3.09  $       6.18
BMW OEM 18211728332 Muffler Hanger 1  $       5.28  $       5.28
BMW OEM 33413404150 Castle Nut 2  $       1.00  $       2.00
BMW OEM 33521105047 Spacer Tube 2  $       9.62  $    19.24
BMW OEM 33521111118 Rear Upper Shock Mount 2  $    41.02  $    82.04
BMW OEM 31131108374 Rubber Mounting (Bushing) 2  $    25.95  $    51.90
BMW OEM 33531104073 Rubber Spring for Rear Suspension 2  $    28.30  $    56.60
         Total   $  812.40
Edited by diathermic
lowered price
~ looking, learning, yearning ~
  • 7 months later...
  • 2 months later...
