Porsche rear brakes and axel refurb
Kidasters
Well - I'm not the documentarian that Jim is.  I never take the time to stop and take pictures step by step.
A few weeks ago - it started with changing brake pads.  When the pistons wouldn't press back into the bores, I figured that means that it's time for new calipers.
PMB Performance in Sandy, UT does this.  For $313 (+100 for cores), you can get a set of refurb'd calipers.  I happened to have a really crappy set of rears for a Carrera out in the parts horde, so in the same day I sent them back some cores for my refund.
The new calipers look really nice
While I was at it, I also removed the left side 1/2 shaft
I have the new 1/2 shafts, as well as new lock washers.  Jim - if you decide to do your CV joints, and need new lock washers - call me.  I ordered some from McMaster-Carr, and the minimum order was 100.
So - in 2 hours this morning, I did the following:
Cleaned up old bleed screws (included running them through a die to clean all the crap out of the threads - 8 mm x 1.25).
Cut flexible line.  Suspend line over plastic container and catch 80% of the brake fluid that ran out (the other 20% is under the tile now.
Work really hard and free clip that locks flexible line end in place.  Remove and let soak in degreaser.
Unscrew hardline from old caliper.
Clean up hardline with steel wool.  Probably need to paint it.
Remove old caliper bolts.  Holy smokes they are tight, and whoever did it last time used lock-tight.  Top one came off when I used my 24" ratchet wrench.  Bottom one came off with the help of a dead blow hammer.
Cleaned up bolts and washers in degreaser.  Ran bolts through 12 mm x 1.5 die to clean threads out.
Re-attach caliper.
Install new pads, wear sensor, retainer spring, pins.
Here's the end result:
Edited by Kidasters
FAQ Member # 2616
-- My wife.
  • 3 weeks later...
Not many pictures again, but more progress.  I worked on the right side axle yesterday.  Went much faster, got the old half shaft out, pulled the caliper, got the old brake hose out, new hose in, new halfshaft in, new caliper in, new pads.  Today, I bled the system.  Thought I had it, but took a test drive and there's just a little bit of air left in the system.  Probably need to go around and bleed all 4 one more time.  Crap.  I don't have the energy for that today.
The good news is that I had help:
which reminded me of a time about 10 years ago, when I had help before:
They grow up fast.....
FAQ Member # 2616
-- My wife.
It never ends.
I finally got the air out of the brakes.  That's in good shape now.  However - more problems.  When I had the car out yesterday, it started spitting a little rain.  I turned on the wipers, and there's a "popping" noise when they are on, like it's a bad relay or something.  Now - on a Porsche, that particular relay (for the wipers) is on the firewall underneath the fresh air blower.  Oh fun.
Also - turned on the fan and it squeaked and squealed.  Not good.
Pulled out the fresh air blower today.  Got the motor out, and will replace it - but also noticed the foam on the flappers is toast.  Ordered some of those off of e-bay for a million dollars.  Also ordered a new relay.
It's always something.
FAQ Member # 2616
-- My wife.
Drove the project car today. Wipers have 2 speeds. Slow, and slower.
But, 70 here. I had to make sure the a/c still worked! :D
Cheers,
Ray
Yesterday, ordered the following:
Blower motor, "squirrel cage" and mount
Relay
Gasket
heater hose
Hope to get it all before next weekend.  We'll see.
Jim - bet your car doesn't look like this:
FAQ Member # 2616
-- My wife.
Still waiting for a gasket, but the relay has been changed, the fan motor changed and the foam around the flappers on the fan changed.
The gasket is the gasket that goes to the distribution pipe that goes down to the evaporator in the smuggler's box.  I'm also waiting for a small hose.
Here's the rebuilt blower system:
FAQ Member # 2616
-- My wife.
