I'd try posting in the Parts Wanted section, and hope another member has one. Is this the padded top piece with the metal VIN tag?
John in VA
early and late column tops are different. early were flat. later had bump to accomodate back of steering wheel.
bottom pieces different also. early metal, later plastic.
the top and bottom pieces are interchangeable.
HOWEVER, the screws that hold them together are NOT interchangeable.  you must use the four screws that were designed for the TOP piece when assembling a different combination.
