Caliper/brake Line Torque Specs??
Hey All,
Just put new.. well remaned calipers on my '70 '02.. does anyone know the torque specs for the caliper mounting bolts, the steel brake line to caliper, and bleeder valves? I did see the torque sheet wich is RAD.. but was mostly engine comps... any help would be greatly appreciated!
1970 BMW 2002, 2005 VW PASSAT GLX 4MOTION WAGON   :ph34r:
I just found every torque spec you could need. Here are the Brake specs.. Ill get the others to the proper person to add to the list.
Caliper - 68.7 ft lbs
Collar nut on brake line 8.7-11.6 same for the hose
Hey All,
Select "brake" tab on top of the Excel sheet.
https://docs.google.com/spreadsheet/lv?key=0AmkUA5H2QQFFdFVVZkNuSk5UWVhNQkdrcnFobnF6TFE&f=true&noheader=false&gid=10
76 2002 Sienabraun
98 328IS Schwarz II
