Looking for info on the new N20 turbos...
C02
I was thinking of adding a turbo(s) to the M10 at some point (MS, etc.). So I try hunting down some info on what two smaller(?) turbos were used on the new BMW N20 (better boost at lower rpms?). Still haven't found the details on the turbos but I did run across this cool video:
...I'm probably late to the realization that one day I might be taking apart motors that were put mostly together by robots.
Any one have any info on the smaller turbo specs?
/Martin
5.3.1.�Function�of�TwinScroll�exhaust�turbocharger
The�designation�TwinScroll�denotes�an�exhaust�turbocharger�with�a�twin-scroll�turbine�housing.�The
exhaust�gas�from�two�cylinders�in�each�case�is�routed�separately�to�the�turbine.�In�the�N20�engine�(as
is�usual�in�4-cylinder�engines)�cylinders�1�and�4�and�cylinders�2�and�3�are�brought�together�to�form�two
ports�each�feeding�one�scroll.�This�results�in�pulse�charging�which�is�used�to�greater�effect.
Pressure�and�pulse�charging
Two�principles�of�forced�induction�are�used�in�engines�with�exhaust�turbochargers�–�pressure�and
pulse�charging.�Pressure�charging�means�that�the�pressure�ahead�of�the�turbine�is�approximately
constant.�The�energy�which�drives�the�exhaust�turbocharger�is�obtained�from�the�pressure�difference
before�and�after�the�turbine.
In�the�case�of�pulse�charging,�the�pressure�before�the�turbine�is�high-speed�and�greatly�fluctuating,�or
pulsating�by�the�discharge�of�the�exhaust�gas�from�the�combustion�chamber.�The�pressure�increase
results�in�a�pressure�wave�which�strikes�the�turbine.�In�this�case,�the�kinetic�energy�of�the�exhaust�gas
is�used,�whereby�the�pressure�waves�drive�the�turbocharger.
Pulse�charging�provides�for�a�fast�response�by�the�turbocharger,�especially�at�low�speeds,�because
pulsation�is�at�its�strongest�here,�whereas�in�the�case�of�pressure�charging�the�pressure�difference
between�before�and�after�the�turbine�is�still�low.
In�actual�fact,�both�principles�are�always�used�in�exhaust�turbochargers�in�passenger�car�engines.�The
proportion�of�pulse�charging�is�higher�or�lower,�depending�on�the�size�factors,�the�exhaust�port�guides
and�the�number�of�cylinders.
Dependence�on�the�number�of�cylinders
In�a�single-cylinder�engine�there�is�an�exhaust�cycle�every�two�revolutions�of�the�crankshaft.
Theoretically,�exhaust�gas�is�therefore�discharged�for�180°�every�720°�crank�angle.�The�graphic�below
shows�in�highly�simplified�form�the�pressure�conditions�before�the�exhaust�turbocharger�in�a�singlecylinder
�engine.
'64 R27 250cc #383851 18,000m
