How to fix my lazy tach
zephyr125
The one in my 73 does it as well. I cleaned everything up and put in a higher quality ground on the IP, but it didn't solve the problem. Maybe the issue is on the coil side?
- Justin
1973 2002tii
The toolbox is where truth and contentment lie... -James May
I had the same problem on my 76. I tried all the connections and an aux ground at the console, still not working. Then I cleaned all the connections on the coil and used a pair of pliers to tighten up the connectors so they fit tighter. Problem solved. Forgot which wire was the correct one so I did them all.
1976 2002 - sold off to a new home
1971 2002 project. Follow Me!- http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,362574/
it's not done right til I've done it twice
I'll try this and report back, thanks!
'74 2002
'82 R65LS
'98 Audi A4
Marineuro.com
