Anyone use this Specialty Products 83115 Rear Camber Kit?
gastephens
Yeah I know it says Datsun but the application guide says it will fit a 2002 also.
Specialty Product 83115
Instructions
My understanding of how it works:
You cut big circles in one of the rear control arm mounting tabs. The hexagons sit in those circles and rotate to allow you to change bolt angle. Then you lock it down with the cam-shaped gizmo and the sheet metal screw.
It seems like if you moved them so they are offset front to back it would change the toe as well.
BMW Lotus Healey Miata x 2
Enlarge the crossmember holes to 1 1/8” with
the 73010 hole punch.
...no....
Gawd, no- the tabs are already weak, and
can't be more than about 30mm...
That said, with some work, it might actually be a decent setup.
You'd need to do more fab than they say, though!
heh
