32/36 insulator gasket
madpaddler
After reading many posts using the search method trying to improve my hot start performance I realize there is no insulation gasket between the carb and the manifold. (The car starts hard the first time, then starts immediately if restart in less than 5 minutes, anytime after about 5-10 minutes hard to start again.) Can anyone recommend the best thickness and type to use?
'76 2002 A "camo blue"
'73 2002 A Chamonix
'71 Airstream Globetrotter
'72 2002 A Verona-crashed then stolen
2007 Toyota FJ
thanks, I noticed there are different thicknesses and wondered what the best would be. Noticed there are 7mm and 12mm thick...just wondered what the preference was as the best and why?
'73 2002 A Chamonix
2007 Toyota FJ
Thanks, that is good info...I'll check current clearance, add 1/4" to the top of my air filter and see if there is any issues.
Thanks for the good advise to all.
'73 2002 A Chamonix
2007 Toyota FJ
