Air Filter Ad Nauseum
ought2
I was all set to replace my K&N rectangular filter with the stock set-up until I realized that my strut brace interferes. There was some reference to the universal K&N plenum recently. It can be purchased with a Weber adaptor. The design uses a remote air filter which ideally would be mounted where it can access air outside the engine compartment - much like the stock snorkel design does. The problem, as I see it, is finding a location for the remote filter without exposing it to bugs, road grit and the elements. (Thanks Mike) Has anybody tried this? Ideas or thoughts? Thanks.
Never let school get in the way of your education!
On the E30 M3, air is taken in via an air trumpet mounted in the low-pressure area behind the bumper cover. US-spec cars used slatted openings in the bumper fascia with a curved trumpet (cheap, thin plastic) and a thru-the radiator support tube and gasket, while the Evo and Euro-cars used a straight trumpet and covers over openings in the bumper. Air pressure, or probably more correctly air turbulence, is well controlled this way. Voila, cool, outside the engine compartment air, little to no turbulence, and protected from rain and bugs. Look at the E30 M3 parts on penskeparts, bmwinfo, or online facory diagrams of choice. Maybe the drawings will help you figure out or adapt something similar.
I would think the same idea might be used behind the front lower apron of the nose. Just don't mount it too low in case you ever drive through a deep puddle. You don't want to hydrolock.
David
Thank you, David. That's great information. I'll post what I come up with for a solution. K&N advertising refers to their variety of universal filters to be used with the plenum. My first task will be to find a suitable space.
ez....pull removable panel in front of engine compt on drivers side. put filter where the battery used to be.
sounds like a great solution. I'll do it. Do you have a picture of this setup? I'm also looking to replace the RamFlo foam filter with a paper throw away type. Any suggestions?
Previously: 1940 BMW 327, 1951 MGTD, 1965 MGB,1967 BMW 1602, 1969 Lotus Elan, 1970 BMW 2002,
1972 BMW 2002tii, 1973 Porsche 914, 1983 MB 240D, 1987 MB 300D, 1987 VW GTI, 1997 MB E320, 1992 & 1999 Miata
Currently: 1976 2002, 1993 MB 300TE, 2004 MB E320
