Valve guide advise
nbristow01
I had my head rebuilt a few months ago. The reason I did was because I had blue smoke after a long decel, then gas it. The seals were shot in it. So the guys rebuild the head, stick in a new 284 cam, new seals ..everything else was reused, valves, rockers etc.
They told me they did not replace the guides because they were within spec? Well this was an original head on this car and it had 80k miles on it.
Do you guys think it is possible that these guides were still good? I have read that these cars wear guides more quickly than many other types of cars.
I install the rebuilt head and I still have the same blue smoke after a long decel when i gas it
Shold I just rebuild this head again? I have all new parts for an entire head rebuild but hate wastng parts and money if it is not needed
Thanks=
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
YES THE GUIDES WEAR
with worn guides, the valve stem can over work
a new seal, and cause it to leak, put more side stress
over time making the seal fail.
find a machine shop that knows about guides,
proper replacement technique, and resizing
after installation - testing the side play of the
valve stem - - -
now to the bottom end of the motor................. ?
got cylinder leak test of blow-by past cylinder
and rings ? rebuilding a head sometimes leads
to more pressure by-passing a worn cylinder-piston-rings
...... and more reading here-=> http://www.aa1car.com/library/ar696.htm
and here -==>> http://www.enginebuildermag.com/Article/2166/valve_guide_reconditioning.aspx
....and this is a good one ....>>>> http://www.hotrodlane.cc/New%20LS%20Links%20Page/LS%20Engine%20Overhaul/Valve%20Guide%20Reaming-Valve%20and%20Seat%20Grinding.htm
and the other details you want right when paying for a head 'overhaul'
'64 R27 250cc #383851 18,000m
the biggest problem is the old valve stem seals. the old style sucked. they just didnt last. later style seals are way better, but you gotta change the guides in order to use the later seals, unless this has already been done. iirc, the old seals were dark brown or black, the later seals are green or red
Ken Inn
the valve stem. When you drive them out, it makes the ID of the guide that much larger and the fit even worse.
Find a new machine shop, they either don't know, or don't care about doing a good job
John N
Thats kind of how I felt when I left with the "rebuilt" head..just a lack of care
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
It's possible that the guides were within spec,
if the 80k motor wasn't revved all that high.
But agreed, the older seals weren't all that great.
I WOULD leak the entire motor before I went any further-
oil can be drawn up around tired rings just as easily
as down through valve guides...
