DIN Versus SAE Battery Terminal Posts
For some writing I'm doing, I'm trying to clarify the standardization, or lack thereof, of battery posts. Traditional top posts are usually referred to as SAE posts. There's an SAE spec for this, published and apparently unambiguous, calling for a 1:9 taper, and a top post size of 17.5mm (positive) and 15.9mm (negative). But there are also occasional references to "DIN posts" that, depending on what you read, are either larger or smaller. Note that this is distinct from "JIS pencil posts" on certain Japanese cars, which are well-defined and definitely smaller.
I found the attached drawing in an Exide battery replacement catalog, which lists the top dimensions of SAE and DIN as being substantially different, but further investigation makes me believe that the DIN dimension is mistakenly labeled at the top, and should be at the bottom.
Does anyone have any direct experience with this -- with SAE terminals and DIN cables not fitting each other -- or are they close enough for government work?
--Rob
post-32582-0-83578500-1429546480_thumb.p
Edited by thehackmechanic
1972 tii (Louie), 1973 2002 (Hampton), 1975 ti tribute (Bertha), 1972 Bavaria, 1973 3.0CSi, 1979 Euro 635CSi, 1999 Z3, 1999 M Coupe, 2003 530i sport, 1974 Lotus Europa Twin Cam Special (I know, I know...)
i once had issues with my toyota pick-up, it eventualy enlarged by itself (??)
i do have original cables on my 02 and they seems to fit the common available batteries without modifications.
Oh and my XR4TI came with the F*** fox type when i bought it in 1992 lol...
1985 XR4TI, 22psi ±300hp
