Tii Fuel Injector Tubes Source?????
Patman
Do you need one NOW? or are you looking to get a set and replace them in the next week or two?
If you have a broken one and need to replace it NOW, post up which one you are looking for. Odd chance that one of the older dealers might have one lying in their stock.
Check with Jack at JF Pro. He should have some. Also try Rob at 2002Haus or Carl at LaJolla.
If you are going to order a set and are not in a rush, check with the usual sources above and Blunt.
Steve J
& too many bikes
Thanks Steve,
I only have one tube that's a little funky. The nut isn't turning on the tube so I had to spin the tube as I unthreaded it from the injector pump.
My cylinder head is at JF ProBimmer now so I'll contact Jack to see if he's got the one tube I'll need. I should be picking up my newly reworked head on Friday.
Pat
74 2002tii known as "The Pickle"
