Air conditioning kits
harrym2
Where would be a good place to but a new universal air conditioning kit from , the sort of kit you can get for classic trucks you know the one fits all type of kit
Try this place I have had good luck with them they bend over backwards. Even made me a custom fitting for my original evaperator. looks like this might even fit inside of a standard 2002 center console. http://www.nostalgicairparts.com/air-conditioning/ud-500-under-dash-air-only-thin-evaporator-608.php
Ozzy hope the bracket worked out sounds like everything is up and working.
1972-2002 "polaris"
2000 M5 "Dieter"
2004 330i "ILKA"
thanks for all the info , do you have any pictures of your air con fitted in your cars
Mine came with a fridgeking unit (BMW aftermarket for 2002) and i just redid everything. I kept the original evaporator and replaced everthing else. I tossed the york compressor and got a sanden 508 and had a bracket built, new hoses, fittings and dryer. I also bought a new condenser 11"x 18 with electric fan. all from http://www.nostalgicairparts.com/air-conditioning/universal-r-134a-hose-kit-with-drier-359.php I will see if I can find some shots in the car. What are you looking for?
Dave
1972-2002 "polaris"
2000 M5 "Dieter"
2004 330i "ILKA"
Dave, who did the bracket? This is the bracket that mounts the compressor to the block? Is it driven by a separate belt? Thanks
Bob
BMWCCA #4844 (#297 of The 308)
1974 2002 Sahara, MM 2400 Rally engine, MM 5 speed and conversion
1976 2002A Anthracite parts car
1991 525i AlpinweiB II
2002 330ci AlpinweiB III
2007 530xiT Titanium Silver
I went to a great place here in Houston. Dropped it off on a Weds and they had it ready on Monday. The AC blows nice and cold. Seeing it was an ALL New system and a bigger condenser, I had them use 134a.
I a really happy with it! Wish I had done it sooner. Instead of spending money on continually fixing the old dealer installed AC. Now I have a brand new system with a warranty.
Could not have done it with out (02hobiedave) Dave having those brackets made to fit the rotary compressor. Thanks again!
CUSTOM CAR COOL
1525-C North Post Oak Road
Houston, TX 77055
(713) 680 9664
www.customcarcool.com
1975 2002A VIN 2380612
https://www.bmw2002faq.com/registry/ - Register your car!
