SK Racing side-drafts setup?
Baikal.2002
DOES IT RUN ?
any vacuum felt at those fittings?
are they float chamber vents ?
did they win any races ?
remove the covers and see where the
holes run to - you going to that anyway
to clean the jets and bowls ? aren't you?
According to tech at twminduction the open tubes/ports are the breather to the cold start unit. These are mounted on Cannon manifolds hooked to a 1.8 on a parts car I purchased for the motor and 5 speed. I've cranked the engine over and it has spark but no fuel. The fuel pump should come in tomorrow so if all goes well it'll be running this weekend. Hopefully the pair are well tuned as two owners back is a mechanic who daily drove the car but its been sitting since 05. I'll rebuild the carbs sooner or later depending upon how they run.
