Custom S14-M2 engine mounts
Lee
  • Replies 42
  • Created
  • Last Reply
Top Posters In This Topic
I would also like, pedal box cable thinggy, air box mount, pulse wheel set if you have them.
Engine mounts - Expected on Wednesday or Thursday
Trigger wheel set - I have plenty
Airbox mount - ???? DCOE-to-S14 ITB adapters?
Pedal box cable thingy - Currently working on one device.
Also, expect a Motorsport lower oil pan for S14 with 1.5 extra quart of oil and fully baffled. It will possibly have optional cooling fins underneath.
Brake harder. Go faster.
Hi Lee,
Im interested in the engine mounts to move the s14 back towards the firewall. My only concern is:
1. I have a RHD car so will the mounts be suitable?
2. I'm using the Getrag 265 dogleg gearbox which may have clearance issues with steering tie rod
3. would I need to shorten the propshaft. I'm currently using the front half of a E30 M3 propshaft fit to the rear half of my original 2002tii shaft that bolts onto the diff.
4. I'm assuming the diff can be moved back to which would avoid shortening the propshaft?
please advise
Thanks
Divyesh
Yes
No experience with this transmission.
If engine moves back by any distance, then the DS must be shortened by the same amount.
The diff can only be moved by a few millimeters.
I was confirmed today that I should get the engine mounts on Friday. Better be Friday morning as I have to install the engine mounts (and weld them too), and then do the tranny mounts at the same time, on Friday, before storing the car on Saturday. Arghhh. Will post pictures.
Lee
BTW Here's the updated list
01-Mike_B
02- David Blair
03- Pete in Japan
04- Ponchis
05- Kevin B.
06- DMaraglia
07- Mark from SD
08- "Anonymous" ( FAQ's Stig)
09- Add your name (Only one set remaining on this batch)
10 - My own set.
Here are the parts. Laser cut and CNC folded stainless steel. Pictures show the different configuraton possibles. On the passenger side, there are two slotted positions. If you want another, just grind the tabs off and locate the plate where ever you want. The engine can be raised by 3mm depending on if the side plates are located under or above the plate.
On the driver side, the main adapter can be used with your own original bracket. Small holes have been cut, and you must enlarge the ones you need. You can also use the supplied bracket which can be welded in any deisred position. Therefore this kit is like Koni's multi-adjustable shocks. It is not one-position-fits-all. It's up to you to tailor your own mounts. So, welding will be required.
$110usd + shipping
Passenger side mount assembled and TIG welded
Moving back the engine allows for a more comfortable clearance between the radiator and the engine. It also improves weight distribution as the engine AND the tranny are moved back. Less weight in front of the axle too. No need to buy a CF hood to lighten the front end. I could even put a fan with viscious clutch.
Now. Here are adapters to install DCOE airhorns on S14 ITBs for the ultimate vintage look. Mounting holes for the DCOE horns must be threaded. Alen bolts supplied. Loctite them in place.
$45usd/pair + shipping
Also, here's the S14 oil pan baffle. Al mounting holes fit perfectly.
$55usd + shipping
The engine mounts are ready to ship. This first batch will be supplied with TWO sets of backing plates. A set with 3.3mm thickness, and a second final set with 4.5mm thickness (thicker than stock, which is 3.3mm). The thinner ones are supplied for you to make some fitment tests.
Price is $110usd + shipping + 4% Paypal fee and the first batch is sold out to the people on the list. Please contact me at massivebrakes@gmail.com so that I can estimate shipping to your location.
TIA
Lee
