wanted: brake fluid resevoir mounting bracket
jerry
i'll be damned if i didn't JUST throw out the remains of a rusty old 02 with the bracket i now need!!!!!
i did not realize that my 68 1600 has a different mounting location for the brake fluid reservoir and i'd like to use the familiar location above the master cylinder.
i saved as much of that car in sheet metal as i could but i didn't think that bracket would ever be necessary for the parts stash.
thanks in advance. fabricating one is my next alternative.
anyone??
jerryallsmanATyahooDOTcom
& 1 special alfa
Aren't they spot welded?
I could cut one off/out for ya?
jonny
actually, all the ones i've seen are very poorly tack welded on with a Mig welder. could probably be touched with a grinder/cutter and cold chisel.
let me know what you want for your efforts and postage.
cheers.
& 1 special alfa
