first timer rear wheel bearing questions
76bimmer
2002 FAQ,
As you will see by questions, I am new at this.
I am packing the rear wheel bearings on my 76 2002.
I purchased new seals but the bearings look good so I am going to reuse them.
How important is it to put the outside bearing back on the outside and the inside bearing back on the inside? Does it matter?
Also, is there a front and back side to the bearings? To me it does not seem to matter as they don't seem to be tapered.
Any help is appreciated. Thanks.
76bimmer.
-= DO NOT RE-USE REAR WHEEL BEARINGs ! =-
You 'might not know' what to look for when examining
old bearing rollers and races to be the judge of their
condition. Heat, galling, metal pickup, noise, wear
are all fine details to know about when inspecting used
roller and ball bearings. JUST as important is your time!.
Do you want to see a wheel pass you due to poor judgement?
Do you have unlimited time on your hands to re do this repair
soon?
ALSO - if your stub axle and wheel flange splines fit together loosely,
if the two slide together with little to no effort - your splines are
also worn and should be replaced with the bearings. Your retightening
of the axle nut on a fatigued stub axle and flange is surefire
point for metal failure - and axle seperation from the car.
here is where you need to inspect your stub axle and wheel flange splined for rusting, wear, errosion of metal causing failure
'64 R27 250cc #383851 18,000m
