Welding drain holes, Questions
justinevert
What works best, do you put in the plates on top of the holes or underneath when you butt-weld them in?
Where can I get that 3M 5200 seal sealer, or do you recommmend the stuff that Por15 has?
Using a micometer, what would be the decimal read out for the various gauge of sheet metal (20, 18, 16) more curious than anything
If the floorboards have no damage (still have the factor primer on them), would it be overkill to cover them with Herciliner before laying over FatMat?
What do you all prefer, acid etched primer (green stuff) or Por15 treatment process?
Again, I can not thank you enough, maybe one day I can figure out how to send pics using that PhotoBucket system.
Justin
The question is not that we broke a few rules or took certain liberties with our female guests.
We did ;)
Charlie don't surf!!
By drain holes you means the approx 3-4" holes in the floorpan? Why weld them? clean the up with a wire wheel and 'glue' them back into place, they twist to lock in place - do this with wet paint, POR-15 or your fav primer - or seam sealer.
Seam Sealer if you only need a little ask your local panel shop, it might only cost you a 6 pack :)
For 'gauge' thickness see here:
http://en.wikipedia.org/wiki/Sheet_metal_gauge
POR-15 or acid etch? Over factory primer I would just use a normal primer.
With loading pics - open a post in the TEST forum (just for testing - thats why its there) - below where you type is the 'Add an Attachment' field, click 'Browse' to locate your file, then click 'Add Attachment' - job done.
HTH Beaner7102
