1994 530i OEM wheels?
ndn73tii
That wheel is from a E39 5 series. The bolt pattern and offset are the same as your E34. The center bore is larger on the E39, you'll need a set of hub-centering rings to fit them on your E34. $ 29.95 for the set at bavauto.com, part number 74 7256.
HTH
Great guy and wealth of knowledge. He helped me with a fuel pump harness issue.
These were taken at their Show and Shine last fall in their parking lot.
1972 2000tii Touring #3422489
FAQ member #5
