Blinkers don't wort.. but....
lsixt
Do the horn and backup lights work? If not, replace Fuse 6.
Remove Fuse 2 (hazard lights). Turn key to ignition position. Flip turn signal switch on. Very slowly move hazard switch in and out through it's full range. Does the turn signal work for any position of the hazard switch? If so, the hazard switch is bad.
Curt Ingraham
1972 2002tii, 1976 2002
Improved 2002 Radiators
and yours is working, eh? Now you have some troubleshooting to do on the TS switch and wiring.
1. Reinstall all fuses. Turn key to ignition position. Hazard switch in OFF position. Check for 12 volts at white/violet wire at hazard switch. If zero volts, trace white/violet wire back to Fuse 6. If 12 volts, continue.
2. Check for 12 volts at green/violet wire at hazard switch. If zero volts, replace hazard switch. If 12 volts, continue.
3. Verify that TS switch is firmloy plugged in under the dash.
Advise results.
Curt Ingraham
