Torsion springs on 'bonnet' Is there a way to restore tensio
PeterVarga
Response for CK....Thanks for the URL....If I remember correctly, I removed the entire unit, inspected it and the end slots were not deformed, just dirt and paint. They were 'normal' to the mount and therefore changing them end for end didn't affect the preload in either direction. And the strange thing is that when I got the car, they worked fine. I think they just fatigued. I don't think they got swapped out.
I guess the last resort fix is have the foundry heat them and reset their offset and quench them. But how did they fatigue in the first place!
If you can, try to "pre-load" (or pre-tension) the bars before you bolt it back in - try rotating one end cap so there is already tension in the bars when it's open. You'll probably need to fiddle with the end cap position to get it right.
After 30+ years there will be some fatigue but I don't t think you need to go the foundry route.
Good luck
Colin K.
Malaga '72 tii
  • 4 months later...
Final Final on the springs....purchased replacments
installed them. Fixed the problem. Seller listed
springs in 'great condition' and infact, springwise,
they were. The lesson here is look at the offset
angle at the ends of the torsion spring. They should
be 90 degrees. The worn out set were about 45 degrees
offset. It makes a difference.
