cold start problem also!
chuncomunco
I have this feeling that my cold start valve might be going bad. It takes me over a minute to get the car fired up. It takes a little shorter time if the cars been left off for a couple hours, but still takes too many cranks to start.
the starter: S14 brand new
(2760940) 1972 2002Tii Agave, Supersprint Headers, IE SS Exhaust, BMP SSK, Crane XR3000 w/ MSD Blaster, IE 284 cams, JB Racing Aluminum Flywheel, Seral 13x6
Follow the diagnostic procedures in the Repair Manual. You will know soon enough if it's working correctly.
Another thing that can cause long cold start cranking times is a malfunctioning ballast resistor bypass relay. It can be as simple as a wire falling off. If the resistor doesn't get shorted during cranking, the spark voltage will be low.
Curt Ingraham
1972 2002tii, 1976 2002
Improved 2002 Radiators
i have a brand new blue coil without an external resistor. i'm running the crane xr700 ignition system. i hope it isnt failing me already!
