Gas smell inside car...
ifayeoh
Is GONE!! Pulled tank and cleaned it up and did not find any obvious holes. never had any gas leaks when filling up but the smell was always there. had it blasted at the local sand blasting joint and por-15'd the outside and used the sealer for the inside. Must have had some pin hole leaks in the seam of the tank. All good now, wont have to replace the hoses whew.
FO 2573825
1971 2002, 5-OD, Recaro SE, BBK, 90Amp Alt, Turbines, VDO, Hellas, BD belts, LED Tails, 10 Foot DD
