I need help getting my hazard lights to work................
PSloan
My car has a brand new hazard switch and an electronic flasher relay. The turn signals work and the hazard switch lights up - but when I engage it, the lights dont flash and if the blinker was on it turns off. If I remember correctly when i tried an early hazard switch i could get the flashers to work but not the turn signals. Any ideas? The purple wire off the back of the switch dead ends - but i thought that just went to the stereo anyways? I really need to get my car inspected so if you guys have any ideas........
Patrick Sloan
1975 inka 2002 - 2375719
1991 325iC
2001 325i
this is advice from my vw van- because my 02 has always worked i havnt looked into it-
BUT: I had a no go on the blinkers/hazards and tracked the problem to the steering column, where (in the van) a resister had been shoved up against metal grounding out the signal. I have no idea if the 02 has a resister in the circuit, but a black tape good wrapping of all the wiring where it rubbed against metal solved my problem.
hoepfully its as simple as that-
'70 project
