I HAVE DUAL 40 WEBER'S W/ A 288 DEGREE CAM. IT WOULD SEEM THAT THE 3 AND 4 CYLANDERS ARENT FIREING. THIS IS ONLY AT IDLE. THERE IS A SPARK. IM WONDERING IF IT COULD BE AN IDLE JET ON THE CARB. ANY THOUGHT WOULD BE GREAT. THANKS.
ANDREW
CHECK:
compression - FIRST
valve adjustment (COLD 0.006")
correct firing order of spark plug wires
rear carb - float, idle jets, carb mounting loose/leaking?
brake booster vacuum hose connected to rear manifold? loose/leaking?
'64 R27 250cc #383851 18,000m
Sounds like a float problem
Also...
Be sure the piston/plungers in the cold start mechanisms are in the proper position. Are the plugs fouling?
76 2002 40 DCOEx2 292 Shrick
1984 Mercedes-Benz 300D Turbo Diesel 240,000 miles
