E21 2.0 Cylinder Head
AustrianVespaGuy
Price: $350
Description:
Been holding on to this backup head for quite a while but think I just don't really need to keep it anymore.  Rebuilt E21 2.0 head with a 284 reground camshaft ca 2008.  I had slapped this on my stock engine for maybe 5000 miles from 2009-2011, but then ended up pulling out the engine for the full rebuild and Megasquirt conversion, at which point I rebuilt the original matching head and put it back on instead.  No oil sparer bar included and it's also not drilled for a mechanical fuel pump.  I think this is best suited for someone who's after a bolt-on-and-go head; probably not for you if you intend to do you own full head rebuild, as it's still fresh enough that I don't think it's worth tearing down again right now.  Reminder: will work fine with flat-top pistons but higher compression raised pistons need to be properly matched with the correct head!
Edited by AustrianVespaGuy
  • 2 months later...
  • 11 months later...
