FS: G245 transmission plus accessories (socal)
The 1 Car Garage
Transmission came out of my 1982 BMW 320i (E21) and I no longer have any use for it, as I did a engine swap. It was in really good condition last time I drove the car a month ago. It was honestly the best part of the car, shifted great and never let me down.
I'm including the clutch and pressure plate, which have good amount of life left. The transmission mount and flex disc (guibi), both appear to be somewhat new, and the clutch slave cylinder which works good, no leaks and has functioned perfectly since owning the car. It even had the reverse light switch, which also functions as intended.
This would be a perfect drop in upgrade for an 2002 or E21 4spd. The only things I would replace would be the throw-out bearing and the seals, as it had a small amount of leaking at the shifter select shaft.
Asking $700 OBO
Located in Cypress 90630
Cheers0592fe7addd0ad317774e7a97f5a4d75.jpg40a5714720120844bdeb1ae9f853ff5e.jpgd4aeb75c82942ed13576a7a0dd7fe704.jpg5f4b9e9b1b4a376367d16dee9fd2e1d8.jpg3151b3438dddf8a8275d9d8a89f3d0b5.jpgd656aa6173139ebfecb1040a2454a9e4.jpgbd4c8c07550dc0fb122a10b8bf4f1fbf.jpg1bc5df7731e4f9fa0f21e6e8c9c13a99.jpg5c185507db887a50139696b35ea7c6e9.jpg
Sent from my Nexus 6P using Tapatalk
