DCOE Backfiring
-ignition timing might be retarded a bit.
-distributor advance not working properly (springs loose). or maybe 180 deg. out
-plug wires not in correct firing order.
-crack on distributor cap
-points bad
-valve clearances not up to spec.
-intake manifold leak
-exhaust manifold leak a hairline crack will do it.
-blown head gasket
-engine compression low
now on the carb side:
1.idle jets too small
2.idle mixture screws not properly adjusted (average 1.5 - 2.5 turns from closed position or when the idle speed is at it highest)
3.when engine is cold side draft/s tend to backfire or spit, wait till engine is at operating temp.
After doing a little research I found that my "pre-setup" carb from TEP was nothing more than a stock out-of-the-box setup from weber. After calling them on it, they said it should be fine just like that. It wasn't, I had to change the main jets, the idle jets, etc.. etc.. It took a lot of trial and error but once I got it dialed in, that single 45 sure ran sweet!
