M2/s14 engine harness with ARC2 for MAF converison
eurotrash
Guys.  I was prepping to put my S14 top end parts up for sale over the weekend,  I sold the head/cam carrier and pucks locally, and thus I officially will not be needing any of the S14 top end and electrics.
The harness is from an M2 that was totaled.
This is a pre-built and working M2 harness with only two cuts that I could see.  They look to be main power and ground connections.  There are at least three sensors still connected, and  plug wires with loom will be in the box as well.  It has the ARC2 air/fuel ratio controller for MAF conversion (450$ new), and is removable, per the installation instructions on their website.
The pictured fuel rail is damaged and not included in this sale ad individually, but I can include it and the stock injectors for an additional expense.
Similarly, I also have the Dinan chipped ECU. The motor had stock cam and injectors.  I would imagine the tune is a go if your motor is set up this way.  Again, I will price this as an add on.
I also have the full intake system, less the air door.
Message me if interested in this, or to ask about any of the other bits. (throttle bodies, venturi, accumulator, water pipe, exhaust down pipe, Idle control valve, stock cams, etc.)
$1200 for the ready made M2 harness described above, shipped to your door.
Add $250 for the fuel rail and injectors if purchased with the harness.
Add $350 for the Dinan Gen 4 chipped 071 ECU if purchased with the harness.
Edited by eurotrash
(O=o00o=O)
