sunroof cable woes- and repair
here is the problem
New cable that is just too short and it popped off and I popped- I was so pissed! I repaired it. First i cut the outer spring that is wound around the cable. I removed as much as possible. As you can see in the pic there is a spot where it is brazed and you cannot remove it. It was just enough.
Then I reamed the crimed part open by hammering a piece of steel down into it to spread the dimples enough to get it back onto the cable. Then crimped the hell out of it. Finally i filed it a little so that it would fit back into the track and slide easily.
Now it all works like a dream! Just hope that the other side will hold up.
I HAD THE SAME PROBLEM BUT FIXED IT DIFFERENTLY .
I HAD A NEW CABLE FAIL WITHIN A WEEK - SAME THING .
I FIXED IT WITH JB WELD . CALL ME CRAZY BUT IT IS STILL WORKING .
I COATED THE CABLE END WITH GLUE AND STUCK IT BACK
IN THE HOLE . THEN I FORMED A LUMP OF GLUE ON THE
END OF THE CABLE THAT STICKS THROUGH .
I HAD TO FILE IT A LITTLE TO GET IT RUNNING THROUGH THE TRACK .
NEXT THING YOU KNOW THE OTHER SIDE BREAKS !
I HAVE A NEW CABLE FOR THE RIGHT SIDE AND I PLAN TO
FIX IT BEFORE IT GOES IN THE CAR .
out in the field by whatever means available, not just following the tech manual. I.e. what we '02 owners do every time we have a breakdown on a trip and don't have the "proper" parts or to fix according to what the shop manual says to do... Similar to "jury rigging"
Word trivia for today.
Mike
I was on the aircraft carrier U.S.S. Dwight D. Eisenhower, CVN-69 for 4 years, (1980-1984) our division officer used to use that word pretty often.
Tim
'74 2002
'69 2000
'89 Corolla
