Oil Pump Prime?
I just finished rebuilding my engine, OS pistons, new valve guides ect.... Its in the car now and I hope to finish the plumbing and start it in the next couple days. Do I need to worry about priming the oil pump? If so, how do I do it?
if you have assembled with a lot of oil or assembly grease,
you should be fine. I you assembled dry, take everything
apart again and rebuild using the run-in oil you intend to use.
But specially priming is not necessary, I never did and never
had problems (with the oilpump that is.....)
Hugo
Thanks Hugo, I used a lot of lube durring assembly but didnt want to kill my new baby by not priming the pump if I needed to.
Thanks Again
Fred
Before trying to START the motor, turn the starter and let it turn a few seconds or so with the coil wire unplugged so you will be pumping oil thru the motor at very low rpm with no combustion.
Steve P. in NC
If you've used assembly lube everywhere on your bearings
surfaces.. pull the plugs out... and spin it over till it has good oil
pressure.. put the plugs in.. check the timming and now's when
the fun starts
The idiot light doesn't tell you much. Perhaps the best $50 you can spend is a mechanical oil pressure gauge and a hydraulic hose. Summit Racing has decent inexpensive gauges.
Mike
