how can you tell if an engine block NEEDS to be bored?
a ridge at the top of the cylinder its a safe bet that it should be bored.
So fess up Carl, what are you thinking about doing now?
i've got that extra m20 sitting in the garage, so i was thinking of trying to rebuild it as a budget 2.7 stroker using a 524td crankshaft and eta pistons. it has a ton of miles on it, though, and if it had to get bored out, i'd have to get custom pistons, which would kill the 'budget' part of the equation.
If you can feel a ridge at the top of the cylinder, it sure needs to be rebored. I did build many engines, some with scratches on the wall, some with ridges. You can live with a scratch but not with a ridge. It will eat up the rings or the land into the piston because the ring is not perpendicular to the walls then.
I did race a VW in another life, 1.8L GTI engine, i did open the engine every race, honned the block and changed rings every time. i did it at least 5 times. The block was severely scratched, it eated up some sand (oval semi dirt race). Engine never smoke, no ridge. I finaly sold the engine to somebody, he still run the car, a 82 Scrirocco. He his very happy of the power, bet that he dont know that this engine has revved 8krpm many many times...
Pat
