Seems to be alot of Computer guys here. Will trade some real
I've noticed alot of you on the board are IT's or into computers, as
I've been a FAQer since Steve, Rob and Trent conceived the idea.
I'm looking for some PC parts to build a system for a digital audio
workstation, and I'll trade for my performance, or really nice stock
stuff, although I'd rather have the cash. Please email me with what
you have to work with.I also have stock parts that have been
restored, bought new and never used, or just those little pieces
that you're trying to find. I don't have any of these parts here, so
I'm going by memory, and this list is not all inclusive.
Performance/Usefull Stock parts:
-an MSD PROGRAMMABLE TIMING COMPUTER. The more
expensive model, Allows you to adjust timing advance starting
point, rate, and final advance infinitly, plus more.
-Brand new PERTRONIX IGNITOR. points replacement model
number 1847V,
-FLAMETHROWER COIL. Used for a few months, but no flaws.
-BIG BRAKE PARTS. complete 320i rear brakes, 528 master
cylinder (the correct one to use for this conversion), ATE vented
calipers from Volvo,
-Complete 318i fuel injection system pulled off a working car by
2002Restorations in Oregon (I cleaned it all up, but have not used
it),
-Complete '87 Volvo/Bosch LH 2.4-Jet fuel injection system with
new wiring harness (the problem on the orig. volvo part was
disintigraded wire insulation) I will part these systems out
possibly.
-PERFECT COPPER 320i RADIATOR, no bent fins, and no clogs.
Was re-cored, so it's newer than the car I pulled it out of. Has
temp. sensor,
-MM Ultimate 4-spd with less than 40k (actually 33k according to
02 head I bought it from; I haven't installed it.) w/ Ireland Heavy
Duty mount, new rear seal installed and will include loose shifter
and front seals,
-Brand new CONTROL ARMS, Mobile Tradition OEM quality
-Brand new BALL-JOINTS with stainless hardware, TRW OEM
quality
-Brand new 215/45R13 Sumitomo HTR 200+ TIRE, never
installed, you need flares and at least 6" wide wheels for these.
Better ratings than alot of the high dollar tires at TireRack.
-4 13x6 BBS basketweaves with BBS center caps. I think they have
an offset of 25, perfect for an 02 with wide tires.
-CUT ST SPRINGS, 1 coil off rears, 1.5 coil off fronts. I made very
clean, straight cuts with my brand new dremel reinforced cutting
wheels.
-ST 19mm REAR ADJUSTABLE BAR, the old, (I think hard to find)
one. They are better than the newer designs because the stiffness
is infinitly adjustable as opposed to having just three positions.
-ST 22mm FRONT BAR. All the ST stuff is vintage (I have receipts
and brochure from ST down in SoCal, but I think it was late '70s)
-COMPLETE SET OF POLYURETHANE BUSHINGS. Never installed.
Some unusual things include 1 pair of rear spring pads, and solid
polyurethane rear-subframe mount inserts.
-CENTER EXHAUST RESONATOR, brand new ANSA made in
Germany. I removed ALL the beginning rust monsters at the
welds, and painted it 1500* (degree) chrome.
-2 EXHAUST DOWNPIPES. Brand new ANSA still have stickers,
never installed.
-FACTORY BUILT BMW m10(e12 head) ENGINE. First round on ALL
parts. Always very well maintained, new water pump, oil pan seal.
Has 165 psi comp. on all cylinders. Sounds too good to be true,
but Rick Haner tested it, as well as Bavarian Motor Sport, both the
best shops I've heard of around here. I have papers from the test.
Perfect compression for a light turbo setup, or just a stock power
plant that will run forever. I prefer someone who can pick it up in
Northern California, but if able I will ship.
-BLUE FLO-FITS. adjustable knee bolsters. Passenger side is still
almost as stiff as new, drivers side has some depression in the
foam, neither have any tears or large stains. There are a few little
stains close to the tranny tunnel from P.O. I kept them covered.
These are more comfortable than the e21 Recaros I've sat in, and
they come with 02 rails. I am something like 5'10" and they put
me at much safer height than the e21 Recaros. The height is
actually adjustable...
-DASHBOARD ABSOLUTELY FLAWLESS in every damn
way you can imagine. Has the double stack slider faceplates,
which are beautiful, Most people who have these are not stupid
enough to sell them, because you can't buy them new, and you
can't restore them.
(I have SOME pics, and I can take some more if you're not in a
hurry)
I'm looking for:
-some kind of Tyan Dual Athlon MP motherboard,
or maybe a new version MSI K7D with AMD 760MPX chipset,
-2 Athlon XP 1600+ thruough 1800+'s (or maybe higher that I
can mod to make MP 2400+'s),
-a really, really, really, really, really, really, really, really quiet high
quality case (I'm thinking Antec SX800II, or that Antec AMG one...
(Whatever the one is that Thermaltake uses to make their cases),
or a Thermaltake case.
-some kind of really, really, really, really, really, really, quiet and
expensive power supply to go with the case. Probably should be a
500 watt for what I'm doing, keep in mind the Dual MP
requirement.
-(depending on the motherboard I use) non-ECC or ECC 512MB
DDR 2100 or higher. Mushkin, dual bank Black memory. If
someone can hook me up with a Dual MP board, which requires
ECC memory, then Crucial, Mushkin, (not Value-RAM) Kingston,
Samsung, Infineon, Mitsubishi, or (not value-select) Corsair
memory in 512MB or 1GB sticks with ECC will be perfect. I'll
consider anything else that I can use for a digital audio
workstation- fast hard drives, additional pro-audio sound cards,
TC Electronics cards, etc.
URL: http://www.spies.com/~reverb/reviews/comp/celebration4416.html
as there's plenty of hardware you could use too. You never know what kind of great old outboard tube-gear people have sitting around, or things like TC Electronic Finalizer/+ (which I have), mic-preamps, compressors (a Distressor pair would be nice), Tascam DA78/98HRs, HHB Portadats and other gear. I have an HHB PDR1000 and a DA78hr myself for my live recordings. Frankly the computer related gear doesn't have much trading value, and the outboard stuff isn't really that much better. My recordings are all in the surf/instro genre and this review was a release earlier this year that I did on DA38/DA88s. The '02 connection is that I'm pictured on the cover taling to three chicks wearing my Golf-colored BMW t-shirt. I master more CDs than I record normally.
I gotta have something I can record all this gear onto. So that's
why I limited it to the computer genre of audio gear. I already
have all this stuff like a patchbay, sampler, a couple $100 mics,
cables up the wazoo, a cheap Alesis stereo compressor, my guitar
rack with a Stereo Comp/Gate/Limiter and Roland DEP-5, a '68
Fender Vibro Champ, and unknown year Ampeg mercury with all
the old US tubes (not surf amps :). Now I could play surf with the
Peavey Classic 30, or my new TubeWorks 100-Watt head though...
Which I need a speaker cabinet for.,,
OK, so I'm also lookin' for some more microphones. Especially a
pair of large diaphragm condensor mics or AKG D 112 or Sure
Beta 52, but anything goes, tube or high end preamps with any
kind of additional on-board frills, mixers, headphone amps,
studio headphones, a TC Electronics Finalizer/+ (or some other
new fancy thing they put out), a really, really, really, really small
minidisc recorder with lots of controls and a stereo mike to go
with it (for bootlegging concerts), a 750MB Zip drive USB, what
else can I think of?
I have all the computer software I need, and if computer gear
doesn't have much trading value then isn't that a good thing? (for
me :))
Thanks f1reverb, got any free CD's I could listen to?
I got a kick out of your link, but it kept going over to
reverbcentral.com before I could read your review.
Plug that sucker into a 2x10 cab, and you'll have a great recording amp. I used to have a '72 Vibro Champ. Is yours a silverface with the black vertical lines?
