WTB Gear Change Selector Bushing
Utah02
Should still be available from the dealer. I would remove the shift lever and determine what other parts you will also need. Most likely the pin that holds the arm joint/pivot to the trans selector shaft. The pin wears and though it may appear minimal it translates to inches by the time you get to the top of the lever. Also might want to replace the joint. The pin is retained by a split, spring steel ring that slides off. There may be another yellow spacer on the joint end as well.
