wheel fitment question for those wearing 15s
I have a set of SSR wheels that I'd like to put on my '76. they're 15x6.5 w/and offset of +45. Will this fit ok? I just don't want to buy a nice set of tires and find out that I have to keep the stock height of the car. I'd like to lower it ~2 inches for auto-X.
thanks for any input
-Charley
p.s. sorry if this is a re-post. I can't get the search to work for some reason.
If the car has no front coil-overs (which implies thcker that stock struts because of the sleeve) you can install 205.50.15 tires on 15 x 6.5/7 rims with offsets up to 30mm. If you have cil-overs, then offset is reduced to 27/28mm depending on tires (RA1s is a bit rounder at the shoulder than V700s).
My racecar run 205.50.15 RA1s on Kosei K1s with 27mm offset along with sleeved struts.
The back can accomodate 3 or 4 mm more offset. Front will require camber plates for a perfect fit. Rear lipses need rolling.
