Pulling To The Right Whilst Braking... Not Brakes?!
mavhh
Are you really, really, really sure you bled properly?!
I did the sequence using pressure bleeder: Bottom servo, top servo, push pedal slowly down and slowly release, clutch, rear left, rear right, push pedal slowly down and slowly release. flont left (top, outer, inner), front right (top, outer, inner). I let at least 500ml through each step. Cup of tea. Repeat the whole sequence. It's amazing how much bleeding it takes to get all the bubbles!
Are you really sure you set the rear shoes right? Without the nuts tightened up the setup was complete rubbish.
Last thing (and this is the stupid one) - I'd used my front right tyre to drive the pressure bleeder... and due to some small leaks in the feed reservior lid... the tyre was only 20psi for the first 50 yards of the test drive. This also caused a pull to the right :)
