Starting problems
I have a 71 1602 all stock. I have some electrical gremlins that are really making me scratch my head. Can't get the car started The starter is going in slow motion- turning over about one crank every two seconds and then speed to a normal pace and then revert to the slow mo again.
Here's what I have done to isolate- battery is good. Trickle charged and checked holding a charge of about 12.65v. My next step is to check the main positive/negative cable connections and cleaning ensure continuity. I have noticed two other things- 1) that the small battery to body ground connection that comes off the negative pole gets really hot (plastic melting hot) during cranking ( it has good continuity all the way to the body) and 2) when getting out of the car I have a small static charge that sparks when I open the door using my left hand.
This all might be a premature request for advice once I clean the major connections, but is there anything else I should look at / consider?
This site awesome- I have used the site for fixing the blinker light mod and fixing a gas tank issue. Many thanks in advance.
R/Barry W
Portsmouth, VA
[/u]
J B Westerwick
Portsmouth VA
78 Alfa Romeo Veloce Spyder
86 Alfa Romeo Veloce Spyder
71 1602 Sahara
YES - attend to the batt-to-body GROUND cable - tight and clean metal
contact at both ends
motor-to-body ground cable needed
cable from batt POS-to-STARTER needs attention
'64 R27 250cc #383851 18,000m
the shock you get when exiting the car is nothing to be concerned about - static build-up. Clean your connections.
