Sanden A/C Compressor Model Number?
Gil. H.
Most folks go with the Sanden 508 for R12, however due to low demand, Sanden has discontinued R-12 models. This includes the following R-12 compressor series (SD505, SD507, SD508, SD509, SD510, SD708, SD709, TR70, TRF90, and TRF105). There are R134a replacements for the R12 models in most cases. This info is from the Sanden FAQ page;
http://www.sanden.com/index.php?tag=1VQR27PTC
74 02Lux
02 M Roadster
72 Volvo 1800ES
74 02Lux
15 M235i
72 Volvo 1800ES
You can still run R12 on the newer compressors.
The difference between R12 or R134 compressors is O ring fittings for R134 vs Flare fittings for the R12.
Some of the older R12 compressors have schrader valve service ports on the back of the compressor too.
So if you want to stay with R12 compatible fittings on a new R134 comressor, you can still do it using O ring to Flare adapters that only cost a few bucks each.
2002 owner since 1980
Just make sure you have the correct oil in the compressor for the refigerant to be used. The oil used in R134a systems is not compatible with R12 or the dessicant used in the R12 rec/drier.
Earl
74 02Lux
15 M235i
72 Volvo 1800ES
