differential behaviour
bills2002
I am about to put the project car on the ground and wire up the engine. I connected the driveshaft last night and it went in great. Today after I had put the car in gear to check clearance of the shift linkage, the prop shaft wouldn't turn...that's good. But when I was messing around with the rear end I was able to turn the rear wheels by hand, with it in gear...not good?
Or is this appropriate (the rear wheels both turned in opposite directions)?
UhOh, I am starting to feel the heat of flame coming on, you can call me a noob on this one;-)
1974 polaris A 4281992 (total resto with 5-spd conversion)
1976 jadegrun 2744974 (sold then killed by the new owner, grrrr!)
1976 sahara A 2392532 (sold)
1971 nevada 2571108(RIP)
Whew, disregard! I had a helper hold one rear wheel in place while I tried to turn the other. With the car in gear it wouldn't turn but when I took it out of gear it spun easily. This must be normal behaviour...go back to your regularly scheduled programing.
