Same Old Question - Crane XR700
cxzsaq
Sorry for the old question - but just want to make sure im getting the right model...
I have a 72tii - vacuum-less distributor.
Is this the model i need:
Crane 700-0292 XR700
Thanks. Have a pleasant weekend.
Thanks Justin for your suggestion!
Yep... That'll work.
You want to use the #220 shutter wheel (marking on the side).
Be sure you're at TDC when setting it up and that the shutter opening is just coming to the sensor.
Cheers!
1976 BMW 2002
1990 Porsche 964 C4 Cabriolet
One last question, do you think I need to also upgrade the coil? I have a stock black. Thanks.
Cheers!
My reply was not a Blanket YES.
READ the instructions. You may need to measure the resistance currently at the coil to be sure you're within limits.
These are 30+ y.o. cars and who knows what mods or errors exist.
If not enough resistance, the Crane Box will burn up!
The Crane is a good system, once setup properly, you'll really like it. Set it up wrong and you'll wish you'd stayed with points.
Cheers!
1976 BMW 2002
Cheers!
Sorry, my reply was misleading. I'll check resistance but was thinking of getting the red coil (and resistors) just in case. I did some searches on the forum and fell that it's still, as you said an "individual" issue because of the age of the cars and their po's wild wiring skills.
Thanks again for your help, I appreciate it much.
