32/36 jets
gobi1
So, a while back I spoke of failing emission testing up here in British Columbia in my '75 2002a. Got some sage advice and checked float level, timing, all ignition components, then decided to change up the main jets. Stock jets in a 32/36 appear to be 140, so I backed up all the way to twin 120s. It drove well until about 50 mph, then seemed to starve for gas. Well the emission testing station was only 2 km away, so I went for it. Result...sailed through! Reading for CO dropped to negligible. Now I will swap jets again and go up to say...130s and try this as a compromise between using so much fuel I was over the limit, and using so little I was running too lean. Just some info if you are ever wondering about those 140s in your 32/36. Mike
75 2002a, 72 3.0CSA, 54 AH 100-4, 61 Bugeye, 64 AH 3000, 67 Airstream Overlander
......give these a try -
Float Level 40mm
PRIMARY
idle 60
main 140
air correction 145
SECONDARY
idle 55
main 170
air correction 175
AND -PLUG THE SECONDARY ENRICHMENT HOLE
AT THE TOP OF THE CARB AS MY DIAGRAM SHOWS.
SEE THE HUGE DIFFERANCE IN ACCURATE FUEL
METERING THROUGH OUT ALL RPM AND THROTTLE OPENINGS.
and this assumes you use a timing light
to set the timing? and yer valves are adjusted
to about 0.006" cold - otherwise forgitaboutitt
'64 R27 250cc #383851 18,000m
Great info, thanks for posting. I have been wondering about those valves, cannot remember when last adjusted. I will check these and continue to refine. Mike
...and it's not so much just the 'main" jets,
it's the matching of the 'air correction' to 'main' jet
for smooth power delivery accross 1/4 throttle
opening , low rpm, transitioning up to 3/4 - FULL
throttle and high rpm - they both effect each other
make sure your compression is healthy
(above 140 psi), valves adjusted (0.006"),
dwell(if you have points 59degrees or 0.016")
and timing using a light setting the ball in the
inspection hole next to the starter motor
at 1500 rpm and no vacuum hoses connected
to the distributor if you have any while performing the
timing check. Reattach the vac advance hose after setting.
another often missed fine detail - while holding your gas pedal to the floor,
stand outside the door so you can see if the carb linkage it tapping the
FULL OPEN STOP on the carb. Adjust your fire wall rod as needed,
or possible your pedal box throttle lever is positioned incorrectly on it's splines???
but adjust so with moderate pressure on the gas pedal to the floor - the carB is indeed opening fully against it's stop.
happy spring time
