KMAC Camber Kit Installation Problems
Tiger75
I bought a stage 2 camber kit 192016-2 for my 74 Tii.
I have one side almost finished but the special nut/bushing won't screw on the top of my Bilstein strut. The threads on my strut are M 12-1.25 and the threads in the special nut are M 12-1.5.
I have been trying for a week to find out if KMAC has this special nut in M 12 - 1.25 thru my supplier and thru KMAC but I can't get an answer.
Has anyone else had this problem?
Any suggestions on a solution?
Ireland and Ground Control kits require coil over which I don't have. Are there any other kits that work on a stock diameter spring set up?
the K-MAC installs the same as the 'stocl' rubber mount
same washers and spacer order
no strut nut included with kit
sounds like you lost the bilstein nuts,
or using USED shocks that did not include nuts? ??
can you be more clear?
here is the order of the washers & spacer
'64 R27 250cc #383851 18,000m
