Just installed MSD 6AL... engine run-on
I installed my MSD 6AL per the instructions that came with it, I'm running tii dizzy, pertronix and MSD blaster2 coil... The engine keeps running!
Heavy red - Battery +
Heavy black - Ground -
Red - switched (the one that was previously on coil's +) and pertronix red
White - pertronix black
Orange - coil +
Black - coil -
The car starts with no problems, solid idle, good throttle response. But won't stop, I only see the red "L" indicator on the cluster when I turn the ignition key to the "off" position.
I tried this: while engine running I disconnected the switched source (the one connected to msd's red and pertronix red) and immediately died. And then I cranked it and, of course, it wouldn't start. I couldn't find anything similar on my dear friend SEARCH.
Please help!
Jorge.
"The BMW 2002 VIN 3634086 was manufactured on November 13th, 1972 and delivered on November 17th, 1972 to Guatemala. The original colour was Polaris metallic, paint code 060" + Factory sunroof + Frigiking A/C
If you read in the destructions. That is a problem with external regulated alternators. You have to solder in a diode on one of the alternator wire's. Sorry i didn't have the problem so i don't know which one. But is is in the book that came with the box. Good luck!
Old enough to know better, young enough to do it again.
