Gearbox problem
SBriggs
I have a problem going from 3rd to 2nd gear in as much as it does not engage easily (only at low revs). Is there an inherent weakness or anything obvious I should be looking for? All other gears going up and down work just fine. There are no unnatural sounds coming from the gearbox, I have only noticed that the gear leaver is not rigid and can spin around.
1973 BMW 2002 Tii
1973 Dino 246 GT
1973 Porsche 911 T
1964 Lotus 7 SII Cosworth
shore up the shifter platform - under the car
"shifter restoration"
flush the brake/clutch fluid - be amazed how much better a car shifts
when the hydraulic mud is flushed out and replaced
with clear, water-free fluid in the system!
