FS: Enkei 13" X5 1/2"rims
alp
  • 1 month later...
width of the wheel AT THE TIRE BEAD (not the outer edge) is 5.5
5.5/2 = the center of the wheel, or "0" offset = 2.75in
picture measures the outer edge of the wheel to the mounting face..this is what is normally called "backspace" and is how most american wheels are quoted.
so to convert...if the "0" offset point is 2.75 in from the bead mounting point, and the (for the sake of argument) the distance from the mounting face to the bead edge is 4.75 in, then the offset = 4.75 - 2.75 = 2.0 inches
2 inches x 25.4 mm per inch = 51mm offset
since the real offset measuring point is the outer tire bead mounting point and not the outside edge of the wheel, need to subtract the width of the metal edge...maybe 8-10 mm...so you get offset of about 42mm.
these wheels look like they were designed for a FWD car with a lot of offset. may not work on an 02 without spacers.
someone should do math check on this....;-)
