WTB: Frigiking condensor
danjrusdug
Here is a couple pics of the parallel flow one I installed, I did cut all the way through one of the 2 brackets under the front panel, but left the bracket there
& bent it forward to make space for the new condensor, it hangs off to the drivers side by an inch or two & leaves about an inch or two of the radiator exposed on the passenger side. I left the horn attached to the bracket. I should replace those upper bracket screws with stainless. It is a thin condensor, but a bit wider than I'd like, hence the bracket cut. The fan is stock behr fan w/stock brackets.
2002 owner since 1980
