Help! Cant loosen diff/driveline bolts-is it easier to just
Then use a spanner on the nut. It's quite easy once you've 'practiced' a little. You may need to try a few different spanner sizes to get the flange to lock ok. I think you need a 22/24. Repeat the 'locking' process until you've got all 4 off.
Gil
72 Tii
the rear subframe and then disconnect the driveline or what- not to mention everything wants to spin-first gear wont hold it-any suggestions
