Trailing arm bushing question???
Can the trailing arm bushings be replaced without disconnecting the brake lines? I read the earlier post about removing the entire sub-frame, and that is a little intimidating to me. I pulled the diff and half-shafts yesterday and have new subframe and arm bushings to install. What is the easiest way?
do the job with the subframe in- I seriously doubt it but prove me wrong. The reason I removed the subframe was due to the fact that the most outside bushings on either side are really tight and hard to get to.
Good Luck
