Q: flipped trailing arms?
TimG
Can someone post up a "flipped trailing arms for dummies" DIY? I keep seeing this referred to, but can't find comprehensive information on it.
For instance, how much toe & camber correction do you get at what lowering height? does everything bolt up, or is fabrication needed? Anything else you can think of?
Thanks!
You remove the rear subframe mounts (and replace the bushings if they need it), and turn them up the other way - it moves the whole subframe 10-15mm closer to the body.
You should consider slotting the differential mount tabs on the body to make sure the diff remains in alignment, although (ahem) I haven't done this.
2002tii race car
